BT.com
Wishlist
Dell S2716DG 27" 2560x1440 1ms HDMI DisplayPort USB LED Gaming Monitor
Delivery
Standard Due date unavailable
Experience sharp and undistorted moving images with NVIDIA G-SyncTM and the fastest refresh rate at 144 Hz for sharp, jitter-free graphics that drastically reduce motion blur.
Enjoy incredibly swift and responsive gameplay with minimum input lag at an extremely rapid 1ms panel response time.
Enjoy vivid edge-to-edge gameplay with the Dell 27 Monitor, equipped with crisp QHD resolution - that's 3.68 million pixels - giving you close to two times more details on screen than Full HD.
Dell S2716DG - LED monitor - 27" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
34 kWh
Adaptive-Sync Technology
NVIDIA G-SYNC
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
61.25 cm x 20.03 cm x 41.63 cm
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A+
34 kWh
Diagonal Size
27"
Viewable Size
27"
NVIDIA G-SYNC
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms
Vertical Refresh Rate
30 - 145 Hz
Horizontal Refresh Rate
69.7 - 250.6 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, input select, colour temperature
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% NTSC colour gamut, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, Energy Gauge, backlight dimming control, arsenic-free glass
61.25 cm x 20.03 cm x 41.63 cm - with stand
Bundled with
DisplayPort , HDMI , 4 x USB 3.0 downstream (Type A) , Audio line-out , Headphones , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand
1 x DisplayPort cable , 1 x SuperSpeed USB cable
United Kingdom
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 61.25 cm - depth: 20.03 cm - height: 41.63 cm , Without stand - width: 61.25 cm - depth: 5.56 cm - height: 36.25 cm - weight: 4.4 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
