BT.com
Wishlist
Dell S2415H 24" 1920x1080 6ms VGA HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
Immerse yourself in widescreen clarity and superb audio with a dependable multimedia monitor that connects you seamlessly to the entertainment you love.
Colour:
Diagonally Viewable Size:
60.5 cm
23.8" (23.8-inch wide viewable image size)
Optimal Resolution:
1920 x 1080 at 60 Hz
Aspect Ratio:
Widescreen (16:9)
Built-in Devices:
Integrated speakers
Pixel Pitch:
0.2745mm x 0.2745mm
Brightness:
250 cd/m2 (typical)
Colour Support:
16.7 million colours
Contrast Ratio:
1000: 1 (typical), Dynamic Contrast Ratio : 8 Million:1 (Max)
Backlight Technology:
LED
Viewing Angle:
(178° vertical / 178° horizontal)
Adjustability:
Tilt , built in cable-management
Flat Panel Mount Interface:
VESA (100 mm)
Response Time:
6 ms (gray to gray)
Panel Type, surface:
In-plane switching, Glossy
Display Type:
Widescreen Flat Panel Display
Display Screen Coating:
Glossy with hard coating (3H)
Dell S2415H - LED monitor - Full HD (1080p) - 23.8" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 23.8"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI (MHL), VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
53.91 cm x 18 cm x 40.46 cm
4.25 kg
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, CECP, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A+
24 kWh
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Glare, 72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, ultra wide viewing angle, LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
53.91 cm x 18 cm x 40.46 cm - with stand
4.25 kg
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-6/+22
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand, cable management cover
1 x HDMI cable
36 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 53.91 cm - depth: 4.59 cm - height: 32.11 cm - weight: 3.24 kg , With stand - width: 53.91 cm - depth: 18 cm - height: 40.46 cm - weight: 4.25 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
