BT.com
Wishlist
Dell S2415H 23.8" 1920x1080 6ms VGA HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
Immerse yourself in widescreen clarity and superb audio with a dependable multimedia monitor that connects you seamlessly to the entertainment you love.
Dell S2415H - LED monitor - Full HD (1080p) - 24" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI (MHL), VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
53.91 cm x 18 cm x 40.46 cm
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, CECP, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A+
24 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
Glare, 72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, ultra wide viewing angle, LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
53.91 cm x 18 cm x 40.46 cm - with stand
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-6/+22
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand, cable management cover
1 x HDMI cable
36 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 53.91 cm - depth: 4.59 cm - height: 32.11 cm - weight: 3.24 kg , With stand - width: 53.91 cm - depth: 18 cm - height: 40.46 cm
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£6.87
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.73
£35.97
£48.72
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.27
£17.48
Scroll to top
