BT.com
Wishlist
Dell S2316H 23" 1920x1080 6ms VGA HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
With the expanded viewing area provided by an improved ultra-thin bezel, the Dell 23 Monitor offers a sleek, premium look and exceptional home entertainment experience.
Dell S2316H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
52.07 cm x 17.99 cm x 40.42 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A
34 kWh
23 W
Diagonal Size
23"
Viewable Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Glossy, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Energy Saver
52.07 cm x 17.99 cm x 40.42 cm - with stand
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , VGA , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+21
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x HDMI cable
34 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 52.07 cm - depth: 17.99 cm - height: 40.42 cm , Without stand - width: 52.07 cm - depth: 5.42 cm - height: 31.16 cm - weight: 2.9 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£7.28
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£39.09
£52.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.47
£17.48
Scroll to top
