BT.com
Wishlist
Dell S2240T 21.5" 1920x1080 12ms VGA DVI HDMI LED Monitor
Delivery
Standard Due date unavailable
Flexible and user-friendly for work, school or fun. The Dell 21.5" touch monitor offers you 10-point touch capability with outstanding clarity and usability in a clean, efficient design.
Dell S2240T - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class A
Touch-screen, USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 8000000:1 (dynamic)
Response Time
12 ms (overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
52.25 cm x 20.57 cm x 37.08 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI
3 years warranty
Bundled with
Display Type
Energy Class
Class A
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Brightness w/touchscreen
280 cd/m²
Contrast Ratio
Colour Support
Response Time
12 ms (overdrive)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), English, German, French, Spanish, Japanese
72% (CIE 1931) colour gamut, 84% (CIE 1976) colour gamut, LED edgelight system, Dynamic Dimming, Energy Gauge, Energy Saver, glove touch mode
52.25 cm x 20.57 cm x 37.08 cm - with stand
5.1 kg
Bundled with
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
Movement Resolution
25 ppi
VGA (HD-15) , HDMI , DVI-D , USB 2.0 upstream , Audio line-out
Mechanical
Tilt
Tilt Angle
+10/+60
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, VESA interface support
Stand, cleaning cloth, touch fastener strap
1 x HDMI cable , 1 x USB cable
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 52.25 cm - depth: 20.57 cm - height: 37.08 cm - weight: 5.1 kg , Without stand - width: 52.25 cm - depth: 4.12 cm - height: 31.89 cm - weight: 3.4 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£7.15
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£38.52
£52.15
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.19
Scroll to top
