BT.com
Wishlist
Dell S2216H 21.5" 1920x1080 6ms VGA HDMI LED Monitor
Delivery
Standard Due date unavailable
With the expanded viewing area provided by an improved bezel, the Dell 22 Monitor offers an affordable, sleek design for everyday computing.
Dell S2216H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
18.5 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
48.8 cm x 17.99 cm x 38.57 cm
3.14 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A
29 kWh
18.5 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system
48.8 cm x 17.99 cm x 38.57 cm - with stand
3.14 kg
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , VGA , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+21
Stand
1 x HDMI cable
30 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.8 cm - depth: 17.99 cm - height: 38.57 cm - weight: 3.14 kg , Without stand - width: 48.8 cm - depth: 5.42 cm - height: 29.31 cm - weight: 2.6 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£7.28
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£19.86
£39.09
£52.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£59.47
£17.48
Scroll to top
