BT.com
Wishlist
Dell Professional P2214H 22" 1920x1080 8ms VGA DVI DP IPS LED Mon
Delivery
Standard Due date unavailable
The Dell 22 monitor - P2214H adjusts to fit your work style and provides virtually all the connectivity options you'll need over the course of the day. The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. The Dell 22 monitor - P2214H meets the latest regulatory and environmental standards.
Dell P2214H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 22"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
51.27 cm x 18 cm x 35.42 cm
5.13 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, LED edgelight system, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Energy Saver, Image Enhance, arsenic-free glass
51.27 cm x 18 cm x 35.42 cm - with stand
5.13 kg
Bundled with
DVI-D , DisplayPort , VGA , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
- 5.5/+22
Swivel Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
42 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 51.27 cm - depth: 18 cm - height: 35.42 cm - weight: 5.13 kg , Without stand - width: 51.27 cm - depth: 4.63 cm - height: 30.44 cm - weight: 3.26 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.57
£24.94
£9.80
£18.27
£14.01
Scroll to top
