BT.com
Wishlist
Dell Professional P2014H 49.4cm(19.5 INCH) LED monitor VGA D
Delivery
Standard Due date unavailable
Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
Dell P2014H - LED monitor - 20"
LED-backlit LCD monitor - 20"
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
47.05 cm x 18 cm x 35.42 cm
3.2 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TCO Displays
3 years warranty
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
83% colour gamut, HDCP
47.05 cm x 18 cm x 35.42 cm - with stand
3.2 kg
DVI-D (HDCP) , DisplayPort , VGA , USB upstream , 3 x USB 2.0 downstream
Mechanical
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
TCO Displays
United Kingdom
Power Supply
Internal
20 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 3.2 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£43.03
£26.46
£9.80
£21.79
£19.38
£14.85
Scroll to top
