BT.com
Wishlist
Dell Professional P2014H 19.5" 1600x900 8ms VGA DVI DP IPS LED Mo
Delivery
Standard Due date unavailable
Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
Dell P2014H - LED monitor - 20" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 20"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
47.05 cm x 18 cm x 35.42 cm
4.35 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.2712 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Overdrive technology, 72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, LED edgelight system, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance, arsenic-free glass
47.05 cm x 18 cm x 35.42 cm - with stand
4.35 kg
Bundled with
DVI-D , DisplayPort , VGA , 4 x USB 2.0 downstream (Type A) , USB 2.0 upstream (Type B)
Mechanical
Tilt Angle
- 5.5/+22
Swivel Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x USB cable , 1 x VGA cable , 1 x DisplayPort cable
36 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 4.35 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.57
£24.94
£9.80
£18.27
£14.01
Scroll to top
