BT.com
Wishlist
Dell PowerConnect W-IAP109 Radio Access Point 802.11a/b/g/n
Delivery
Standard Due date unavailable
The multifunctional Dell Networking W-series IAP 109 Remote Access Point delivers secure 802.11n wireless and wired networking, and access to corporate resources from branch and home offices.
With unmatched deployment flexibility, the W-IAP 109 series can operate in Instant mode or in controller-managed mode where all network services are centralized by Dell mobility controllers.
In Instant mode, traffic is locally bridged but it still provides the flexibility of secure tunneling to mobility controllers. The W-IAP 109 offers a wide range of enterprise-class features, including role-based network access, policy-based forwarding, and adaptive radio management (ARM), which optimizes Wi-Fi client performance and ensures that Dell W-series APs stay clear of interference.
At locations that require greater coverage, the W-IAP 109 can join an Instant WLAN cluster. Simply install additional W-series IAP's and the entire cluster is managed as one. If one W-series Instant AP fails, another AP automatically takes over with no disruption.
With dual-radios and wireless data rate up to 300 Mbps in the 2.4-GHz and 5-GHz radio bands, the W-IAP109 delivers high performance 11n wireless capacity and coverage. In addition, the W-IAP109 provides one 10/100/1000BASE-T Ethernet uplink, one 10/100BASE-T local Ethernet port and one USB port to connect to 3G and 4G networks.
Dell PowerConnect W-IAP109 - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
16 cm x 4.3 cm x 16 cm
300 g
Radio access point
Ruggedized Design
Indoor
16 cm
4.3 cm
16 cm
300 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Trusted Platform Module (TPM), 2T2R MIMO technology, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x serial - RJ-45 , 1 x USB 2.0 - Type A
EN 60950, IEC 60950, CB, FCC, EN 301.893, EN 60601-1-2, cTUVus, Directive 72/23/EEC, EN 300 328, EN 301 489
PoE+
12.5 Watt
Limited warranty - lifetime
5 - 95% (non-condensing)
Accessories
£3.70
£12.66
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.83
£49.65
Scroll to top
