BT.com
Wishlist
Dell PowerConnect W-AP105 Radio Access Point 802.11a/b/g/n
Delivery
Standard Due date unavailable
The multifunction Dell PowerConnect W-AP92 and W-AP93 are entry-level indoor, single-radio 802.11n access points (APs) designed for low-density deployments in offices, hospitals, schools and retail stores. These compact, high-speed APs deliver wire-like performance at data rates up to 300 Mbps. The W-AP Access Points and W-Series Controllers complement Dell's existing PowerConnect portfolio of networking solutions, and securely and efficiently extend wired network capabilities to the mobile workforce.
Dell PowerConnect W-AP105 - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE+
13.5 cm x 13.2 cm x 4.5 cm
300 g
1 year warranty
Radio access point
Ruggedized Design
Indoor
13.5 cm
13.2 cm
4.5 cm
300 g
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, wall mountable, Mesh networking, Wi-Fi Multimedia (WMM) support, Trusted Platform Module (TPM), Adaptive Radio Management (ARM), 3T3R MIMO technology
Encryption Algorithm
WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
VCCI, EN 60950, NOM, IEC 60950, UL 60950, CB, CCC, IC, MIC, UL 2043, FCC, R&TTE, KCC, EN 301.893, ANATEL, cTUVus, LVD, SRRC, Directive 72/23/EEC, EN 300 328
PoE+
12.5 Watt
OS Provided
ArubaOS
Limited warranty - 1 year
50 °C
5 - 95% (non-condensing)
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
