BT.com
Wishlist
Dell PowerConnect W-3600 Controller 4x1000BaseT RJ45/1000Base-X
Delivery
Standard Due date unavailable
PowerConnect W-3000 series controllers act as headend devices for enterprise wireless networks that use central controllers to manage complex, processing-intensive management and security functions. PowerConnect W series access points virtualized and implement wireless LAN services and move user traffic to the controllers through secure IP tunnels over a public or private transport network.
Dell PowerConnect W-3600 - network management device
Network management device
External
Ports Qty
4
Performance
3DES throughput: 8 Gbps , AES throughput: 4 Gbps , Firewall throughput: 4 Gbps
IPSec VPN tunnels: 4096 , Active firewall sessions: 128000 , Maximum number of access points: 128 , Maximum number of access points (remote): 512 , Concurrent users: 8192 , Virtual interfaces (VLANs): 512 , IPv4 routes (Unicast): 2048 , MAC addresses: 64000 , Maximum number of configured SSIDs: 1024
AC 120/230 V (47 - 63 Hz)
35.1 cm x 29.7 cm x 4.4 cm
3.4 kg
1 year warranty
35.1 cm
29.7 cm
4.4 cm
3.4 kg
External
Ports Qty
4
Wired
Performance
Encryption Algorithm
Triple DES, AES
1 x management (RS-232) - RJ-45 , 4 x 1000Base-T - RJ-45 , 4 x 1000Base-X - SFP (mini-GBIC)
C-Tick, EN 60950, GS, NOM, EN55024, EN55022 Class A, UL 60950, CSA 22.2 No. 60950, CB, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, MIC, AS/NZS 3548, EN 61000-4-5, EN 61000-4-11, EN 61000-4-8, FCC Part 15 A, ANATEL, cTUVus, VCCI Class A, EN 61000-3
External power adapter
Limited warranty - 1 year
5 - 95% (non-condensing)
Accessories
£3.70
£12.66
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.83
£49.65
Scroll to top
