BT.com
Wishlist
Dell PowerConnect W-3400 Controller 4x1000BaseT RJ45/1000Base-X
Delivery
Standard Due date unavailable
The Dell PowerConnect W-3000 Controller series is a family of three full-featured controllers that addresses a wide range of wireless and wired network mobility, security and remote networking requirements for enterprises of any size. The PowerConnect W-3200 Controller is designed for the small business and branch offices, while the W-3400 Controller is designed for medium/large enterprise or dense office deployments. The W-3000 series is easily installed without disrupting the existing wired network.
The W-3000 series acts as the head-end portion of Dell's wireless LAN architecture, which uses centralized controllers in the data center to manage complex and processing-intensive management and security functions. Edge services are virtualized and implemented in cost-effective PowerConnect W-series access points (APs) at the network edge, which move user traffic to data center controllers through secure IP tunnels over a public or private transport network.
Controller clustering and centralized management allow large enterprise networks with multiple controllers to be managed and maintained with minimal staff overhead. A designated master controller can manage multiple local controllers, or for larger networks, the W-series AirWave Wireless Management Suite (AWMS) provides unprecedented visibility and control for the IT staff.
Dell PowerConnect W-3400 - network management device
Network management device
External
Ports Qty
4
Performance
Firewall throughput: 4 Gbps , 3DES throughput: 4 Gbps , AES throughput: 2 Gbps
Maximum number of access points: 64 , Maximum number of access points (remote): 256 , User licences: 4096 , MAC addresses: 64000 , Active firewall sessions: 128000 , Concurrent IPSec tunnels: 2048 , Virtual interfaces (VLANs): 256 , IPv4 routes (Unicast): 4096 , Maximum number of configured SSIDs: 512
AC 90 - 264 V (47 - 63 Hz)
35.1 cm x 29.7 cm x 4.4 cm
3.2 kg
1 year warranty
35.1 cm
29.7 cm
4.4 cm
3.2 kg
External
Ports Qty
4
Wired
Performance
Encryption Algorithm
Triple DES, AES-CCM
1 x management (RS-232) - RJ-45 , 4 x 1000Base-T - RJ-45 , 4 x 1000Base-X - SFP (mini-GBIC)
C-Tick, CISPR 22 Class A, EN 60950, GS, NOM, EN55024, EN55022 Class A, UL 60950, CB, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, MIC, AS/NZS 3548, EN 61000-4-5, EN 61000-4-11, EN 61000-4-8, FCC Part 15 A, ANATEL, cTUVus, CAN/CSA C22.2 No. 60065, VCCI Class A, EN 61000-3
External power adapter
45 Watt
Limited warranty - 1 year
5 - 95% (non-condensing)
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
