BT.com
Wishlist
Dell P2715Q 27" 3840x2160 6ms HDMI MHL DisplayPort USB 4K IPS LED Monitor
Dell P2715Q 27" 3840x2160 6ms HDMI...
£651.56
£651.56
Add to wishlist
Delivery
Standard Due date unavailable
Exceptional screen clarity.
The Dell 27 Ultra HD 4K monitor has gorgeous resolution. The high pixel density helps you see extremely fine details onscreen so you can view and edit higher resolution photos and more. Create your masterpiece with more clarity and color enhancement - all at a price you can afford.
Nearly perfect color accuracy.
You can count on natural and consistent color across different mediums because each monitor is factory tuned at 99% sRGB with a color calibration factory report certifying that each monitor has a deltaE < 3. That means you get precise color coverage right out of the box at an amazing high-color depth of 1.07 billion colors. Each hue remains consistent from virtually any viewpoint with an ultra-wide viewing angle at 178°/ 178°.
Full adjustability.
Enjoy every detail the Dell 27 Ultra HD 4K Monitor - P2715Q provides in total comfort, thanks to full adjustability.
  • The included stand enables tilt (5° forward or 21° backward), pivot, swivel and even provides built-in cable-management.
  • Customize your viewing experience with a height-adjustable stand, or save desktop space by detaching the stand for wall mounting with a VESA-compatible 100mm x 100mm wall mount kit. (Wall mounting equipment sold separately.)
All-digital connectivity.
Connect easily with other peripherals simultaneously, and view content from your handheld devices on the monitor screen - all without compromising picture quality.
  • With DisplayPort 1.2, you can daisy-chain two monitors side by side by connecting via the DP-in and DP-out ports, eliminating the need to link every one of your monitors to the PC and reducing cable clutter.
  • Charge or power BC1.2-compatible and other USB devices with a high-speed USB 3.0 charging port.
  • Connect to MHL compatible smartphone or tablet and display content directly on the larger monitor screen via MHL.
Eco-conscious design.
The Dell 27 Ultra HD 4K Monitor - P2715Q meets the latest regulatory and environmental standards.
  • ENERGY STAR® Qualified
  • EPEAT® Gold3 Rated
  • TCO Certified Displays
Made with premium-quality materials, this Ultra HD 4K monitor is BFR/PVC-free (excluding external cables) and has arsenic-free glass, a mercury-free LED panel, and a chassis made of more than 25 percent post-consumer recycled materials.
Dell P2715Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI: 30 Hz)
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort, MHL
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
64.074 cm x 20.386 cm x 42.386 cm
7.18 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, TCO Displays
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
29 - 76 Hz
Horizontal Refresh Rate
31 - 140 kHz
Video Bandwidth
533.25 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, sharpness, rotation, input select, colour temperature, uniformity, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), Energy Gauge, Energy Saver, Mercury free, Factory Calibration, Transition Minimised Differential Signaling (TMDS) technology, 77.6% (CIE 1931) colour gamut, 104% (CIE 1976) colour gamut
64.074 cm x 20.386 cm x 42.386 cm - with stand
7.18 kg
4 x USB 3.0 downstream , USB 3.0 upstream , MHL / HDMI , DisplayPort , Mini DisplayPort , DisplayPort output (MST) , Audio line-out
Mechanical
Tilt Angle
-5/+21
Rotation Angle
180
Height Adjustment
115 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Power Supply
Internal
95 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 64.074 cm - depth: 20.386 cm - height: 42.386 cm - weight: 7.18 kg , Without stand - width: 64.074 cm - depth: 5.15 cm - height: 37.966 cm - weight: 5.03 kg
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
Other bundles
Dell P2715Q 27
Dell P2715Q 27" 3840x2160 6ms HDMI MHL DisplayPort USB...
£651.56
Wireless keyboard and mouse set
£701.55
Dell P2715Q 27
£651.56
Keep your electronic devices protected
£671.55
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
Scroll to top
