BT.com
Wishlist
Dell P2416D 23.8" 2560x1440 8ms VGA HDMI DisplayPort USB LED Monitor
Dell P2416D 23.8" 2560x1440 8ms VGA...
£263.88
£263.88
Add to wishlist
Delivery
Standard Due date unavailable
The Dell 24 monitor - P2416D engages you in remarkable quad HD resolution with 1.77 times more details than Full HD and a wide 99% sRGB color coverage. Enjoy the convenience of multiple USB ports, organize applications in a snap on one screen with Dell easy arrange, and maximize productivity with multiple adjustability features.
Dell P2416D - LED monitor - 24" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
LED-backlit LCD monitor - 24"
Energy Class
Class A
Energy Consumption per Year
35 kWh
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.205 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
56.56 cm x 20.5 cm x 36.9 cm
5.95 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A
35 kWh
Diagonal Size
24"
Viewable Size
23.75"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.205 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
49 - 86 Hz
Horizontal Refresh Rate
29 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
Stand lock, 99% sRGB colour gamut, Energy Gauge
56.56 cm x 20.5 cm x 36.9 cm - with stand
5.95 kg
Bundled with
DisplayPort , HDMI , VGA , USB 2.0 upstream , 3 x USB 2.0 downstream
Mechanical
Tilt Angle
- 5.5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable
United Kingdom
35 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 56.56 cm - depth: 4.7 cm - height: 33.51 cm - weight: 3.58 kg , With stand - width: 56.56 cm - depth: 20.5 cm - height: 36.9 cm - weight: 5.95 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Other bundles
Dell P2416D 23.8
Dell P2416D 23.8" 2560x1440 8ms VGA HDMI DisplayPort...
£263.88
Wireless keyboard and mouse set
£313.87
Dell P2416D 23.8
£263.88
Keep your electronic devices protected
£283.87
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
