BT.com
Wishlist
Dell P2314T 23" 1920x1080 8ms VGA HDMI DisplayPort USB IPS LED Touchscreen Monitor
Delivery
Standard Due date unavailable
Use both hands and the responsive 10-point touch capability to quickly and smoothly navigate across the edge-to-edge glass of your P2314T. The ergonomic stand offers optimal application and game control, as well as viewing comfort.
VGA, USB, DP and HDMI ports plus MHL connectivity allows direct display of smartphone/tablet content on the touch monitor while charging your mobile device at the same time.
Dell P2314T - LED monitor - Full HD (1080p) - 23" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 23" - touchscreen
Touch-screen, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
2xHDMI, VGA, 2xMHL, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.99 cm x 8.09 cm x 41.27 cm
6.28 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, ultra wide viewing angle, LED edgelight system, PowerNap, edge-to-edge glass, 10-point multi-touch, BFR/PVC-free, Energy Gauge, glove touch mode, Transition Minimised Differential Signaling (TMDS) technology
56.99 cm x 8.09 cm x 41.27 cm - with stand
6.28 kg
Bundled with
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
2 x MHL / HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt
Tilt Angle
+10/+60
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, VESA interface support
Stand, cleaning cloth, touch fastener strap
1 x HDMI cable , 1 x SuperSpeed USB cable
United Kingdom
26 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 56.99 cm - depth: 8.09 cm - height: 41.27 cm - weight: 6.28 kg , Without stand - width: 56.99 cm - depth: 4.22 cm - height: 34.81 cm - weight: 4.82 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
£9.99
£6.91
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.84
£36.18
£49.00
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£55.62
£17.48
Scroll to top
