BT.com
Wishlist
Dell P2314H 23" 1920x1080 VGA DVI DP USB LED Monitor
Delivery
Standard Due date unavailable
Dell Professional series has productivity, performance and comfort, plus environmentally responsible design and power management features. It is recommended for large enterprises, health-care, education and other performance-driven organizations.
Dell P2314H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advanced Exchange Service and Premium Panel Guarantee
LED-backlit LCD monitor - 23"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
54.58 cm x 18 cm x 36.3 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, RoHS, CECP, CEL, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut
54.58 cm x 18 cm x 36.3 cm - with stand
Bundled with
DVI-D (HDCP) , DisplayPort , VGA , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
Power Supply
Internal
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.58 cm - depth: 18 cm - height: 36.3 cm , Without stand - width: 54.58 cm - depth: 4.65 cm - height: 32.3 cm - weight: 3.34 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
