BT.com
Wishlist
Dell P2217H 21.5" 1920x1080 6ms VGA HDMI DP IPS LED Monitor
Delivery
Standard 1-3 working days
The Dell 22 Monitor | P2217H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
Dell P2217H - without stand - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
19 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
49.89 cm x 5.03 cm x 29.73 cm
Environmental Standards
ENERGY STAR Qualified
RoHS, TCO Displays
Display Type
Energy Class
Class A+
19 kWh
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
72% (CIE 1931) colour gamut, ultra wide viewing angle, 82% (CIE 1976) colour gamut, Premium Panel Guarantee, Dell Easy Arrange, Dell ComfortView
HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), anti-theft protection
RoHS, TCO Displays
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
Without stand - width: 49.89 cm - depth: 5.03 cm - height: 29.73 cm
ENERGY STAR Certified
10 - 80% (non-condensing)
Scroll to top
