BT.com
Wishlist
Dell P1914S 19" 1280x1024 8ms VGA DVI DisplayPort USB IPS LED Monitor - Silver
Delivery
Standard Due date unavailable
Enhance your productivity and liven up your entertainment with sharp screen quality, adjustable viewing features and excellent connectivity options.
Dell P1914S - LED monitor - 19" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 19"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Silver
41.14 cm x 4.65 cm x 33.64 cm
2.76 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.29 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 81 kHz
Video Bandwidth
135 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, PowerNap, stand lock, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Image Enhance
Silver
41.14 cm x 4.65 cm x 33.64 cm - without stand
2.76 kg
Bundled with
DVI-D , DisplayPort , VGA , USB 2.0 upstream , 4 x USB 2.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, VESA interface support
Stand, cable management cover
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
37 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 41.14 cm - depth: 4.65 cm - height: 33.64 cm - weight: 2.76 kg , With stand - width: 41.14 cm - depth: 18 cm - height: 49.97 cm
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£39.98
£24.58
£9.80
£18.00
£13.78
Scroll to top
