BT.com
Wishlist
Dell NSA 220 Wireless-N TotalSecure 1 Yr International
Dell NSA 220 Wireless-N TotalSecure...
£1,714.56
£1,714.56
Add to wishlist
Delivery
Standard Due date unavailable
The Dell SonicWALL Network Security Appliance (NSA) 220 Wireless-N series high-performance next-generation firewall offers branch offices and distributed enterprises in-depth frontline security, application and user control, network productivity and optional 802.11 dual-band wireless. The NSA 220 series firewalls act as the first line of network defense against viruses, Trojans, key-loggers and other application layer attacks, without compromising network performance. Management is simplified by consolidating many functions, including network security, remote access and wireless.
The NSA 220 series offers an extensive array of advanced networking and configuration flexibility features in an accessible, affordable platform that is easy to deploy and manage in a wide variety of environments.
SonicWall NSA 220 Wireless-N TotalSecure - security appliance
Security appliance
Bundled Services
1 year GAV/AS/IPS/Application Intelligence Service/Content Filtering Service and Dynamic Support 24X7
External - 1U
RAM
512 MB
Flash Memory
32 MB
Ports Qty
7
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
Performance
Stateful throughput: 600 Mbps , Gateway anti-virus throughput: 115 Mbps , IPS throughput: 195 Mbps , Full Deep Packet Inspection (DPI) throughput: 110 Mbps , Firewall throughput (IMIX): 180 Mbps , VPN throughput (3DES/AES): 150 Mbps
Connection / user qty: 85000 , DPI connections: 32000 , New sessions per second: 2200 , Authenticated users (internal database): 100
VoIP Protocols
SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
26.7 cm x 18.1 cm x 3.8 cm
0.97 kg
Security appliance
Bundled Services
Height (Rack Units)
1U
26.7 cm
18.1 cm
3.8 cm
0.97 kg
Processor / Memory / Storage
RAM
512 MB
Flash Memory
32 MB
External
Ports Qty
7
Wireless, wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
Routing Protocol
OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz, 5 GHz
Performance
Firewall protection, DHCP support, VPN support, load balancing, Syslog support, DoS attack prevention, content filtering, dynamic DNS server, IPv6 support, antivirus analysis, High Availability, Intrusion Prevention System (IPS), deep inspection, Stateful Failover, DDos attack prevention, MIMO technology, anti-spam protection, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, PKI, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK
Authentication Method
Secure Shell (SSH), RADIUS, X.509 certificates, LDAP, internal user database, Active Directory, Extensible Authentication Protocol (EAP), XAUTH authentication
IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, X.509, IEEE 802.11i, IEEE 802.11n
IP Telephony
VoIP Protocols
IP Telephony Features
VoIP gatekeeper support, VoIP outbound bandwidth management
Aerial
Antenna
External detachable
Antenna Qty
3
Communications
Supported Flash Memory Cards
CompactFlash Card
7 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 2 x USB - Type A
MTBF
15 years
FCC Class A certified, UL, TUV GS, VCCI, C-Tick, cUL, NOM, CB, MIC, RoHS, FIPS 140-2, WEEE, EAL 4+
Internal power supply
15 Watt
Power Provided
36 Watt
OS Provided
SonicOS
5 - 95% (non-condensing)
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.79
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£21.03
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£28.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£19.27
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.48
£39.93
Scroll to top
