BT.com
Wishlist
Dell Networking N1548 Switch 48 Ports Managed Rack-Mountable
Delivery
Standard Due date unavailable
The N1500 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated 10GbE uplinks. The N1500 switch series has high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to handle unexpected traffic loads easily. These switches offer simple management and scalability via a 40Gbps (full-duplex) high-availability stacking architecture that allows management of up to four switches from a single IP address.
Dell Networking N1548 - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching fabric bandwidth: 176 Gbps , Forwarding performance: 164 Mpps
Virtual interfaces (VLANs): 512 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 128 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1023 , Maximum ACL rules per interface (IPv4) egress rules: 1023 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 509 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8 , MAC addresses: 16000
MAC Address Table Size
16000 entries
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
Telnet, TFTP
Auto-negotiation, auto-uplink (auto MDI/MDI-X), port mirroring, Broadcast Storm Control, front to back airflow, redundant fans
44 cm x 25.7 cm x 4.32 cm
4 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16000 entries
Routing Protocol
Telnet, TFTP
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
48 x Gigabit LAN RJ-45 , 4 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Internal power supply
Installed Qty
1
Power Provided
100 Watt
44.6 Watt
Rack Mounting Kit
Included
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
44 cm
25.7 cm
4.32 cm
4 kg
Limited warranty - lifetime
45 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Scroll to top
