BT.com
Wishlist
Dell N3024 Switch L3 Managed 24 x 10/100/1000
Delivery
Standard Due date unavailable
Dell Networking N3024 are an energy-efficient and cost-effective switches designed for modernizing and scaling network infrastructure. N3024 switches utilize a comprehensive enterprise-class Layer 2 and Layer 3 feature set, deliver consistent, simplified management and offer high-availability device and network design. The N3024 switches offer a power-efficient and resilient Gigabit Ethernet (GbE) switching solution with integrated 10GbE uplinks for advanced Layer 3 distribution for offices and campus networks. The N3024 switches have high-performance capabilities and wire-speed performance utilizing a non-blocking architecture to easily handle unexpected traffic loads. Use dual internal hot-swappable 80PLUS-certified power supplies for high availability and power efficiency. The switches offer simple management and scalability via an 84Gbps (full-duplex) high availability stacking architecture that allows management of up to 12 switches from a single IP address.
Dell Networking N3024 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 10 Gigabit SFP+ + 2 x combo Gigabit SFP
Performance
Switching fabric bandwidth: 212 Gbps , Forwarding performance: 158 Mbps , Stacking bandwidth: 84 Gbps
MAC addresses: 16384 , Static routes: 1024 , OSPF routes: 8160 , RIP routes: 512 , Virtual interfaces (VLANs): 128 , IPv4 routes (Multicast): 1536 , IPv6 routes (Multicast): 512 , ARP entries: 6144 , NDP entries: 400 , ACL entries: 100 , ACL rules: 4096
MAC Address Table Size
16K entries
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, PIM-SM, PIM-DM, IGMPv3, OSPFv3, MLDv2, MLD
Remote Management Protocol
SNMP 2, SNMP, RMON, HTTP, SSH
Flow control, Layer 3 switching, Layer 2 switching, MDI/MDI-X switch, auto-negotiation, VLAN support, port mirroring, stackable, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), port forwarding, STP Root Guard, LLDP support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet, dual firmware images, Network Access Control (NAC), tagged VLAN, Generic VLAN Registration Protocol (GVRP)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ag, IEEE 802.1ab (LLDP), IEEE 802.3az
Power Redundancy
Optional
43.4 cm x 40.7 cm x 4.35 cm
6 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Routing Protocol
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
24 x Gigabit LAN RJ-45 , 2 x 10Gbit LAN SFP+ , 2 x Gigabit LAN SFP , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Expansion Slots
1 (total) / 1 (free) x Expansion Slot
Installed Qty
1 (installed) / 2 (max)
Power Redundancy
Optional
Power Provided
200 Watt
52.8 Watt
43.4 cm
40.7 cm
4.35 cm
6 kg
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
Accessories
£3.79
£13.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.40
£52.66
Scroll to top
