BT.com
Wishlist
Dell N2024P Switch L2+ Managed 24 x 10/100/1000
Dell N2024P Switch L2+ Managed 24 x...
£1,362.34
£1,362.34
Add to wishlist
Delivery
Standard Due date unavailable
Dell Networking N2000 is a series of energy-efficient and cost-effective switches designed for modernizing and scaling network infrastructure. N2000 switches utilize a comprehensive enterprise-class Layer 2+ feature set, deliver consistent, simplified management and offer high-availability device and network design. The N2000 switch series offers a power-efficient Gigabit Ethernet (GbE) network-access switching solution with integrated uplinks. The N2000 switch series has high-performance capabilities and wire-speed performance, utilizing a non-blocking architecture to easily handle unexpected traffic loads. The switches offer simple management and scalability via a (full-duplex) high - availability stacking architecture that allows management of up to 12 switches from a single IP address. An integrated power supply and features such as Energy-Efficient Ethernet and short cable detection provide energy efficiency to help decrease power and cooling costs.
Dell Networking N2024P - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
Performance
Switching fabric bandwidth: 172 Gbps , Forwarding performance: 128 Mpps , Stacking bandwidth: 84 Gbps
Virtual interfaces (VLANs): 4096 , ARP entries: 1024 , NDP entries: 400 , Priority queues per port: 8 , IPv4 routes (static): 256 , IPv6 routes (static): 128 , IPv4 routes (dynamic): 256 , VLAN routing interfaces: 256 , ACL: 100 , Max ACL rules system-wide: 2048 , Maximum rules per ACL: 1023 , Maximum ACL rules per interface (IPv4) ingress rules: 1024 , Maximum ACL rules per interface (IPv4) egress rules: 512 , Maximum ACL rules per interface (IPv6) ingress rules: 512 , Maximum ACL rules per interface (IPv6) egress rules: 256 , Maximum VLAN interfaces with ACLs applied: 24 , Maximum aggregation groups: 128 , Maximum dynamic ports per switch stack: 144 , Maximum member ports per LAG: 8
MAC Address Table Size
8192 entries
Routing Protocol
RIP-1, RIP-2, static IPv4 routing, static IPv6 routing
Remote Management Protocol
Telnet, TFTP
Flow control, auto-negotiation, VLAN support, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Access Control List (ACL) support, front to back airflow, IPv4 support, Energy Efficient Ethernet, Management Information Base (MIB), dual firmware images, Neighbor Discovery Protocol (NDP), redundant fans
44 cm x 38.7 cm x 4.35 cm
6.37 kg
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
8192 entries
Routing Protocol
Telnet, TFTP
Encryption Algorithm
MD5, AES, SSL, TLS
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
1 GB
Flash Memory
256 MB
24 x Gigabit LAN RJ-45 PoE+ - 30.8 W , 2 x 10Gbit LAN SFP+ , 1 x serial (RS-232) RJ-45 management , 1 x USB Type A , 2 x network stack device
Internal power supply
Installed Qty
1
Power Provided
1000 Watt
42.9 Watt
Redundant Power System (RPS) connector
Rack Mounting Kit
Included
FCC Class A certified, cUL, GS, RoHS, WEEE, REACH, ICES Class A, VCCI Class A, EAC, CCC Class A
44 cm
38.7 cm
4.35 cm
6.37 kg
Limited warranty - lifetime
45 °C
0 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
65 °C
Humidity Range Storage
0 - 85%
Accessories
£3.81
£13.76
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.46
£53.70
Scroll to top
