BT.com
Wishlist
Dell Latitude 12 Rugged Extreme 7202 Convertible Tablet
Delivery
Standard Due date unavailable
12" Rugged Tablet meets rigorous military-standard requirements. Made with shock-absorbent materials and compression-sealed from sand, dust and liquids.
Performance you can count on: You have everything you need to run your projects with powerful, efficient fifth-generation Intel Core M processors and up to 512GB of fast, reliable solid state storage.
Longer battery life: The Latitude 12 Rugged Tablet powers you through a full shift of projects on the go, and lets you stay untethered with optional dual hot-swap batteries so you never have to shut down apps while changing out a battery.
Easy outdoor readability: Work never stops, regardless of environment. See clearly in direct sunlight on a crisp, 11.6" multi-touch display that responds even while wet or when wearing thick gloves.
Bring the heat: Experience peak performance even in high temperatures with fourth-generation QuadCool fan based thermal management system that combines passive and active cooling.
Tested beyond the limits: No matter where you work - an offshore oil rig, limestone quarry, or overseas military base, carry the Dell Latitude 12 Rugged Tablet with confidence knowing it has been tested for extreme conditions, and proven by MIL-STD-810G and IP-810G certification. Additionally, HZO Protection has been applied to the inside of the device to help keep the tablet safe from water, rain and other environmental risks.
Equipped for real life: Build a productivity solution for any extreme situation with an extensive ecosystem that offers options such as a desk dock, vehicle dock, or a full-size keyboard with an IP-65 rating that protects against water and dust intrusion.
Connect anywhere: Stay on the grid and in touch with what's important using 802.11ac Wi-Fi, optional mobile broadband and dedicated GPS.
With the same protection offered across Latitude and Optiplex lines, you can have peace of mind knowing your important data stays private.
Protect data on any device across external media and in the cloud from advanced malware with Dell Data Protection | Encryption. DDP | E is available from the factory so that IT admins can enable centralized, remote management of encryption policies to easily meet compliance regulations right out of the box.
Ensure only authorized users have access to your data with authentication options including FIPS 201-certified smart card, fingerprint readers or contact-less smart card reader.
Secure credential storage is provided with a FIPS 140-2-certified TPM. Dell ControlVault adds another layer of hardware security by isolating user passwords and credentials on a separately controlled hardware chip.
Full Dell management with Client Command Suite support. Factory Installed with Dell Command | Update allowing users to easily identify and download updates.
Dell Command | Update is also factory installed for easy customization of AC or battery power options, plus with Battery Extender Mode users can prolong battery life with one-click, reducing energy-intense hardware processes. Remotely manage your tablet fleet with optional Intel vPro technology plus Dell unique-capabilities for out-of-band BIOS management that can be applied to multiple systems at once.
The Dell Latitude 12 Rugged Tablet is subjected to rigorous testing to ensure world-class dependability in the most demanding of conditions.
Built to withstand harsh use in military, industrial and field environments; proven by independent testing to MIL- STD-810G and IEC ingress protection ratings.
Corning Gorilla Glass touch display offers an optimal viewing experience with reduced reflectivity, glove-capable multi-touch and outstanding durability.
Your device is also backed by optional enterprise-level Dell ProSupport 24x7 to minimize downtime, all the time.
Dell Latitude 12 Rugged Tablet 7202 - 11.6" - Core M 5Y71 - 8 GB RAM - 128 GB SSD
Tablet - no keyboard - rugged
Operating System
Win 8.1 Pro 64-bit
Intel Core M 5Y71 / 1.2 GHz (2.9 GHz) / 4 MB Cache
8 GB LPDDR3
Storage
128 GB SSD
Display
11.6" touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics 5300
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
2-cell - up to 12 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, SmartCard reader, contactless SmartCard Reader
31.2 cm x 20.3 cm x 2.4 cm
1.62 kg
Pricing Type
BTO
Environmental Standards
ENERGY STAR Qualified
3 years warranty
Included Service
3 Years Dell ProSupport
Operating System
Windows 8.1 Pro 64-bit Edition
Included Service
Processor / Chipset
CPU
Max Turbo Speed
2.9 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB
Max RAM Supported
8 GB
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
128 GB SSD
Display
11.6"
Touchscreen
Yes (10-point multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, Corning Gorilla glass 3
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Resolution
8 Megapixel
Sound
Speaker, two microphones
Communications
Wireless
2-cell Lithium Ion
26 Wh
Run Time
Up to 12 hours
AC Adapter
Input
Output
45 Watt
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 , Mini-HDMI , Micro-serial
Memory Card Reader
Yes (microSD)
Dockable
Security
Power adapter, additional 2-cell battery
MIL-STD-461F, IP65
Pricing Type
BTO
1.62 kg
Limited warranty - 3 years
-29 °C
63 °C
Scroll to top
