BT.com
Wishlist
Dell E5515H 1920x1080 8ms VGA HDMI USB 55" LCD LFD
Delivery
Standard Due date unavailable
The Dell 55 Monitor is designed for convenience and enhanced productivity with easy set-up right out of the box. Great for conference rooms with ambient lighting conditions, the exceptional onscreen clarity and bright images of the 55" monitor provide outstanding views.
Dell E5515H - LED monitor - Full HD (1080p) - 55"
LED-backlit LCD monitor - 55"
Energy Class
Class A+
Energy Consumption per Year
117 kWh
USB 2.0 hub
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.21 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA
124.1 cm x 24.5 cm x 78.6 cm
24.4 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
RoHS
Display Type
Energy Class
Class A+
117 kWh
Diagonal Size
55"
Viewable Size
54.6"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.21 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, input select, phase, aspect control
Anti-glare, 72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, PowerNap, Hard Coating (3H), BFR/PVC-free
124.1 cm x 24.5 cm x 78.6 cm - with stand
24.4 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x HDMI , VGA , Audio line-in , 2 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Flat Panel Mount Interface
400 x 400 mm
Remote control, 2 x AAA batteries, 4 screws
1 x audio cable , 1 x VGA cable , 1 x mini HDMI-HDMI cable , 1 x USB cable
RoHS
United Kingdom
65 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 124.1 cm - depth: 6.48 cm - height: 72.15 cm - weight: 20.3 kg , With stand - width: 124.1 cm - depth: 24.5 cm - height: 78.6 cm - weight: 24.4 kg
ENERGY STAR Certified
20 - 80% (non-condensing)
Accessories
£9.99
£7.28
£39.13
£53.02
Scroll to top
