BT.com
Wishlist
Dell E2416H 24" 1920x1080 5ms VGA DisplayPort LED Monitor
Delivery
Standard Due date unavailable
A reliable and affordable 24" monitor with essential features that meet everyday office demands. It features great display quality at multiple angles with VESA-mount compatibility and tilt options, as well as VGA and DisplayPort. Also it saves energy with power-efficient features.
Dell E2416H - LED monitor - Full HD (1080p) - 24" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
56.696 cm x 18 cm x 42.758 cm
3.6 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, CECP, TCO Displays
3 years warranty
Bundled with
Display Type
Diagonal Size
24"
Viewable Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27675 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, input select, colour temperature, phase, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, LED edgelight system, Energy Gauge, 86% (CIE 1976) colour gamut
56.696 cm x 18 cm x 42.758 cm - with stand
3.6 kg
Bundled with
DisplayPort , VGA
Mechanical
Tilt
Tilt Angle
-6/+22
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand, VESA screw cover
1 x DisplayPort cable
United Kingdom
27 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 56.696 cm - depth: 18 cm - height: 42.758 cm - weight: 3.6 kg , Without stand - width: 56.696 cm - depth: 5.05 cm - height: 33.458 cm - weight: 2.91 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£40.22
£24.72
£9.80
£20.37
£18.12
£13.87
Scroll to top
