BT.com
Wishlist
Dell E2316H 23" 1920x1080 5ms VGA DisplayPort LED Monitor
Delivery
Standard 1-3 working days
A reliable and affordable 23" monitor with essential features that meet everyday office demands. It features Full HD display quality at multiple angles with VESA-mount compatibility and tilt options, as well as VGA and HDMI ports. It also saves energy with power-efficient features.
Dell E2316H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (black-to-white)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
54.48 cm x 5.05 cm x 32.2 cm
2.98 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
RoHS, CECP, TCO Displays
3 years warranty
Bundled with
OptiPlex 3040
Display Type
Diagonal Size
23"
Viewable Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, phase, aspect control
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, Flicker Free technology, Energy Gauge, backlight dimming control
54.48 cm x 5.05 cm x 32.2 cm - without stand
2.98 kg
Bundled with
VGA , DisplayPort
Mechanical
Tilt
Tilt Angle
-6/+22
Flat Panel Mount Interface
100 x 100 mm
Stand, VESA screw cover
1 x DisplayPort cable
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Dell Display Manager
Dimensions & Weight Details
Without stand - width: 54.48 cm - depth: 5.05 cm - height: 32.2 cm - weight: 2.98 kg , With stand - width: 54.48 cm - depth: 18 cm - height: 41.5 cm
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Dell OptiPlex 3040
Accessories
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£39.98
£24.58
£9.80
£18.00
£13.78
Scroll to top
