BT.com
Wishlist
Dell 8GB Certified Memory Module - 2RX8 SODIMM 2400 MHz
Dell 8GB Certified Memory Module -...
£123.33
25 in stock
£123.33
Add to wishlist
Delivery
Standard 1-3 working days
Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Dell - DDR4 - 8 GB - SO-DIMM 260-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Dual rank, unbuffered
Voltage
1.2 V
DELL A9210967, DELL SNPMKYF9C/8G
Inspiron 13 7375 2-in-1, 15 3567, 15 5565, 15 5567, 15 5577 Gaming, 15 Gaming 7566, 17 5767, 20 3064; Latitude 13 3379 2-in-1, 13 3380, 3480, 3580, 5480, 7390, 7490, E7280; Precision Mobile Workstation 3520, 5520; Vostro 15 5568; XPS 15 9560
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Chips Organization
X8
Voltage
1.2 V
Dell Inspiron 13 7375 2-in-1, 15 3567, 15 5565, 15 5567, 15 5577 Gaming, 15 Gaming 7566, 17 5767, 20 3064 , Dell Latitude 13 3379 2-in-1, 13 3380, 3480, 3580, 5480, 7390, 7490, E7280 , Dell Precision Mobile Workstation 3520, 5520 , Dell Vostro 15 5568 , Dell XPS 15 9560
Scroll to top
