BT.com
Wishlist
Dell 4GB Memory Module For DDR3L-1600 UDIMM 1RX8 ECC LV
Delivery
Standard 3-5 working days
Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Dell - DDR3L - 4 GB - DIMM 240-pin
RAM memory
4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Single rank, Low Voltage, unbuffered
Voltage
1.35 V
DELL A7303660
PowerEdge C5220, C6105, C6145, M420, M520, M620, M915, R210 II, R220, R320, R410, R415, R420, R420xr, R515, R520, R610, R620, R715, R720, R720xd, R815, R920, T110 II, T20, T20 Mini Tower Server, T320, T420, T620; Precision T1700; Precision Fixed Workstation T1650
4 GB
Upgrade Type
System specific
DELL A7303660
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
ECC
Chips Organization
X8
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
Dell PowerEdge C5220, C6105, C6145, M420, M520, M620, M915, R210 II, R220, R320, R410, R415, R420, R420xr, R515, R520, R610, R620, R715, R720, R720xd, R815, R920, T110 II, T20, T20 Mini Tower Server, T320, T420, T620 , Dell Precision T1700 , Dell Precision Fixed Workstation T1650
Scroll to top
