BT.com
Wishlist
Dell 22" Monitor P2217H Black No Stand UK 210-AJEE VGA HDMI
Dell 22" Monitor P2217H Black No...
£153.79
More than 50 in stock
£153.79
Add to wishlist
Delivery
Standard 1-3 working days
The Dell 22 Monitor | P2217H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
Dell P2217H - without stand - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
48.5 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
49.89 cm x 5.03 cm x 29.73 cm
2.81 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, TCO Displays, EDID compatible
Display Type
Energy Class
Class A+
48.5 kWh
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% NTSC (CIE 1931) colour gamut, stand lock, 82% NTSC (CIE 1976) colour gamut, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Energy Gauge, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, Dell ComfortView
49.89 cm x 5.03 cm x 29.73 cm - without stand
2.81 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots, arsenic free
1 x VGA cable - VGA to VGA , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
Mounting Kit
Optional
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Display drivers, Dell Display Manager
10 - 80% (non-condensing)
Scroll to top
