BT.com
Wishlist
Dell 16GB Certified Replacement Memory Module 2133 Mhz
Dell 16GB Certified Replacement...
£365.08
£365.08
Add to wishlist
Delivery
Standard 1-3 working days
Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Dell - DDR4 - 16 GB - DIMM 288-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Dual rank, Ultra Low Voltage, registered
Voltage
1.2 V
DELL A7945660
PowerEdge FC630, M630, M630P, M830, R430, R530, R630, R730, R730xd, T430, T630; Precision Tower 5810, 7810, 7910
16 GB
Upgrade Type
System specific
DELL A7945660
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
ECC
Chips Organization
X4
Voltage
1.2 V
Dell PowerEdge FC630, M630, M630P, M830, R430, R530, R630, R730, R730xd, T430, T630 , Dell Precision Tower 5810, 7810, 7910
Scroll to top
