BT.com
Wishlist
Datalogic QuickScan L D2330 Barcode Scanner
Datalogic QuickScan L D2330 Barcode...
£102.26
16 in stock
£102.26
Add to wishlist
Delivery
Standard 1-3 working days
The QuickScan L bar code reader is a bar code scanner with laser technology at an affordable price. The QuickScan L reader is the perfect solution for general purpose users who prefer laser scanning technology and need to read bar codes at nominal distances. This scanner is lightweight and small with an ergonomic form factor which provides the user with ease of scanning during daily operations. Used in retail and office application environments, the QuickScan L reader provides a snappy scanning performance and is capable of reading a wide range of bar codes including the majority of 1D and GS1 DataBar codes (previously known as RSS).
The wider than usual scan angle allows users to read a longer bar code from a shorter distance. The gun shaped ergonomic design fits most users' hands comfortably and the scanner only weighs 4.5oz/128g (without the cable). The QuickScan L reader has been designed with durability in mind. It meets the IP42 sealing rating (against dust and liquid spills) and has a 5ft/1.5m drop specification. This scanner also has a greater than 1 million duty cycle trigger specification as well as sustainable 20kV of Electro Static Discharge (ESD). These are the best class specifications of any product on the market. One of the most vulnerable features of any scanner is damage to the scanner window. When such incidents happen, the scanner may have to be replaced. The QuickScan L reader was specially designed so that the end user can order a replacement window pack and replace the damaged window without having to send the scanner in for repairs.
Datalogic QuickScan L D2330 - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
5 mil
Scan Field Width
13.9 cm - 26.9 cm
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.7 cm x 7.1 cm x 17 cm
128 g
3 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Field Width
13.9 cm - 26.9 cm
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
30%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, IATA, GS1 DataBar, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 128 Full ASCII, Code 39 Trioptic
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS)
1 x USB
Stand
1 x USB cable
TUV, ISO 9001, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, EN 60950, NOM, PCT, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, MIC, RoHS, EN 60825, IEC 60825-1
Electric Current Required
30 mA (standby), 100 mA (typical)
6.7 cm
7.1 cm
17 cm
128 g
Limited warranty - 3 years
50 °C
5 - 95%
Drop Specification
1.5 m to concrete
Scroll to top
