BT.com
Wishlist
Datalogic Generic DATALOGIC QUICKSCAN D2330 BLACK USB KIT
Datalogic Generic DATALOGIC...
£98.64
More than 50 in stock
£98.64
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
Datalogic QuickScan D2330 - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
5 mil
Scan Field Width
13.9 cm - 26.9 cm
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.7 cm x 7.1 cm x 17 cm
128 g
3 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Field Width
13.9 cm - 26.9 cm
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
30%
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, IATA, RSS Code, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey, Code 128 Full ASCII, Code 39 Trioptic
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Reduced Space Symbology (RSS)
1 x USB
1 x USB cable
TUV, ISO 9001, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, EN 60950, NOM, PCT, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, MIC, RoHS, EN 60825, IEC 60825-1
Electric Current Required
30 mA (standby), 100 mA (typical)
6.7 cm
7.1 cm
17 cm
128 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
50 °C
5 - 95%
Drop Specification
1.5 m to concrete
Scroll to top
