BT.com
Wishlist
Datalogic GD4430 Kit USB 2D Imager USB/RS-232/KBW/WE Multi-Interface
Datalogic GD4430 Kit USB 2D Imager...
£247.05
28 in stock
£247.05
Add to wishlist
Delivery
Standard 1-3 working days
The Gryphon 4000 series represents the premium level of data collection devices from Datalogic Scanning for general purpose applications. Designed with people in mind, the Gryphon I GD4400 imager blends advanced 2D reading with motion sensing technology, producing a user-friendly device with outstanding performance.
Perfect for both handheld and presentation reading, the Gryphon I GD4400 imager features Datalogic's Motionix motion-sensing technology which detects the natural actions of the operator to automatically switch the scanner into the desired scanning mode. This technology works with or without the use of a stand, offering more operational choices. Both the aimer and sensor can be programmed to the user's desired preferences.
User comfort is maximized with the Gryphon I GD4400 imager's steady, deep red illumination light. Easier on the eyes than competitive products with flicker illumination, the highly visible 4-Dot aimer defines a precise reading zone and reduces accidental reads. The aimer's center cross provides a locator for targeted scanning in a multiple bar code environment.
The Gryphon I GD4400 2D omnidirectional reader eliminates the need for separate equipment with signature capture and document scanning capabilities. Its enhanced optics offer improved motion tolerance and high speed imaging to read fast moving codes.
Datalogic Gryphon I GD4430 - barcode scanner
Barcode scanner - handheld - keyboard wedge, RS-232, USB, wand - decoded
Scan Element Type
Visible laser diode
Wired
7.1 cm x 10 cm x 18.1 cm
195 g
5 years warranty
Barcode
Interface Type
Keyboard wedge, RS-232, USB, wand
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Skew (Degrees)
40
Pitch (Degrees)
40
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Postnet , PDF417, Data Matrix, PLANET, Australian Post, British Post, China Post, Japanese Post, Kix (Netherlands) Post, Korea Post, MacroPDF417, Royal Mail, Micro QR code, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Composites, GS1 DataBar Stacked, China Han Xin Code
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB , 1 x keyboard wedge , 1 x RS-232 , 1 x - wand
Stand
1 x USB cable
RoHS
Electric Current Required
160 mA (operating), 65 mA (standby)
7.1 cm
10 cm
18.1 cm
195 g
5 years warranty
Service & Support Details
Limited warranty - 5 years , Limited warranty - cable - 90 days
55 °C
0 - 90%
Drop Specification
1.8 m to concrete
Scroll to top
