BT.com
Wishlist
Datalogic Data Logic PowerScan PM8300 Barcode Scanner - USB Kit
Datalogic Data Logic PowerScan...
£697.98
£697.98
Add to wishlist
Delivery
Standard Due date unavailable
The PowerScan PM8300 cordless laser scanners are Datalogic Scanning's premium line of rugged industrial handheld data collection products for linear codes. The mobile phone-like keyboard allows for the manual entering of bar codes that are not readable and enables easy management of simple code-quantity applications like inventory, picking, receiving, etc.
Narrow band radio communications with Datalogic's STAR Cordless System provides the key to increased productivity and flexibility in the workplace. It offers scalable solutions from simple point-to-point applications to networking capabilities combined with seamless roaming for complex installations.
The PM8300 readers feature Datalogic's exclusive 3 Green Lights (3GL) for superior good read feedback. The patented 'Green Spot' directly on the code and dual Good Read LEDs on the top and back of the cap adds increased visibility at any angle. Superior reading performance is enhanced by Datalogic's patented PuzzleSolver technology for fast and accurate reading of standard, poorly printed and damaged codes.
The PM8300 reader's mechanics have been developed and tested to withstand extreme environmental conditions maintaining consistent reading performance without degrading performance or reliability. Its ergonomic enclosure is lightweight and well balanced to ensure optimal operator comfort during scan intensive operations. A built-in metal tether hook for suspended applications ensures workplace productivity.
Datalogic PowerScan PM8300 - barcode scanner
Barcode scanner - handheld - RF - decoded
Minimum Bar Width
7.5 mil
Scan Element Type
Visible laser diode
Scan Speed
35 scan / sec
Wireless
Wireless Connectivity
RF
1 x Lithium Ion
6.9 cm x 11.4 cm x 20.7 cm
395 g
3 years warranty
Black, yellow
Barcode
Interface Type
RF
Minimum Bar Width
7.5 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
630-680 nm
Scan Mode
Single-pass
Scan Speed
35 scan / sec
Skew (Degrees)
60
Pitch (Degrees)
55
Print Contrast Signal (PCS)
15%
Decode Capability
Code 93, Code 39, Code 49, ISBT 128, ISBN, RSS Code, Code 32, Codabar, Code 128, Code 11, Code 16K, ISSN
TTL Decoding
Decoded
Wireless
OK Notification
Beeper, LED indicator
Triggered, waterproof
RF
Display
Display Resolution
96 x 32
Character Resolution
4 lines x 16 characters
1 x USB
Cradle
1 x USB cable - external , 1 x power cable - external
ETSI, EN55022 Class B, AS/NZS 3548, FCC, RoHS, IEC 60825-1
Power adapter - external
1 x Lithium Ion
Software
Software Included
Datalogic Aladdin
6.9 cm
11.4 cm
20.7 cm
395 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
-20 °C
50 °C
0 - 90%
Drop Specification
2 m to concrete
Scroll to top
