BT.com
Wishlist
Datalogic Data Logic PowerScan PD7130
Datalogic Data Logic PowerScan...
£236.84
Hurry, only 3 left in stock!
£236.84
Add to wishlist
Delivery
Standard 1-3 working days
The PowerScan 7100 product series is Datalogic Scanning's value line of rugged industrial handheld data collection product. The PowerScan D7100 linear imaging corded reader combines rugged durability and extremely snappy reading performance all at an affordable price.
Datalogic Scanning's innovative and unique optical design of the PowerScan 7100 series of readers combines scanner features that are normally available on different scanner models into a single device: up to 3 mils maximum code resolution; contact to about 3.0 m / 9.8 ft reading distance; and wide angle code reading. The result is a versatile, easy to use and intuitive scanner that simplifies any code reading activity.
Together high-speed digital hardware and Datalogic Scanning's advanced decoding algorithms produce read rates up to 390 scans per second, making the PowerScan 7100 readers the fastest industrial scanners available. This is why the 7100's are especially suitable for "high-speed" applications where thousands of codes have to be read in a very short period of time
As with all PowerScan products, the 7100 readers' mechanics have been developed and tested to withstand extreme environmental conditions while maintaining consistent reading performance. A loud beeper and Datalogic's exclusive patented ‘Green Spot' directly on the code, provide intuitive good read feedback in noisy environments.
Light weight and instinctive usage combined with outstanding speed-to-read makes the 7100 product series the ideal solution for intensive code reading applications.
Datalogic PowerScan PD7130 - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
3 mil
Scan Element Type
Visible laser diode
Scan Speed
390 scan / sec
Wired
7.6 cm x 11.4 cm x 20.3 cm
280 g
3 years warranty
Black, yellow
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
630-680 nm
Scan Mode
Single-pass
Scan Speed
390 scan / sec
Skew (Degrees)
65
Pitch (Degrees)
65
Print Contrast Signal (PCS)
15%
Decode Capability
Code 93, Industrial 2 of 5, Code 39, ISBT 128, IATA, RSS Code, Code 32, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, Codablock F, Label Codes 4/5
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
1 x USB
IEC 825-1/EN 60825-1 class 1, RoHS
Software
Software Included
Datalogic Aladdin
7.6 cm
11.4 cm
20.3 cm
280 g
3 years warranty
Service & Support Details
Limited warranty - 3 years
-30 °C
50 °C
5 - 95%
Drop Specification
2 m to concrete
Scroll to top
