BT.com
Wishlist
DataCard SP 25 Plus With Input Hopper
Delivery
Standard Due date unavailable
The Datacard SP25 Plus printer offers a unique combination of full-color and rewritable card printing capabilities.
This one-sided printer is designed for low-volume, manual-feed applications and is an ideal solution for issuing retail/loyalty, membership and ID cards.
Datacard SP25 Plus - plastic card printer - colour - dye sublimation/rewritable
Printer Type
Plastic card printer - dye sublimation/rewritable - colour
3.2 kg
Max Media Size
CR-80 Card (85.6 x 54 mm)
Max Media Size (Custom)
54 mm x 86 mm
Print Speed
Up to 120 cards/hour - colour - CR-80 Card (85.6 x 54 mm) , Up to 500 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm)
Max Resolution (B&W)
300 dpi
Max Resolution (Colour)
300 dpi
Image Enhancement Technology
Advanced Imaging Technology
USB
Media Type
PVC card, laminated PVC card, ThermoRewrite card
Printer Features
Borderless printing, ribbon saver
AC 120/230 V
Linux, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2008
2 years warranty
19.5 cm x 37.85 cm x 22.5 cm
Printer Type
Printer
Print Speed
Up to 120 cards/hour - colour - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 500 cards/hour - monochrome - 300 dpi - CR-80 Card (85.6 x 54 mm)
Wired
USB
300 dpi
300 dpi
Printer Features
Media Handling
Media Type
Max Media Size
54 mm x 86 mm
Card / Label Sizes
Media Thickness Range
0.2286 mm - 1.397 mm
1 x USB
Consumables Included
2 x ribbon ( yellow/cyan/magenta ) - up to 250 images
UL, C-Tick, cUL, CCC, FCC, RoHS
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, Datacard ID Works Basic Edition
2 years warranty
Service & Support Details
Limited warranty - 2 years , Limited warranty - printhead - 2 years
15 °C
35 °C
20 - 80% (non-condensing)
19.5 cm
37.85 cm
22.5 cm
3.2 kg
Scroll to top
