BT.com
Wishlist
DataCard SD360 Duplex Printer
£1,179.25
Hurry, only 3 left in stock!
£1,179.25
Add to wishlist
Delivery
Standard 1-3 working days
Bring even more value to your desktop with the Datacard SD360 card printer. Increase productivity and save work time by issuing secure, two-sided ID cards and badges with this best-in-class card printer. Ideal applications include small- to medium-sized businesses, schools, clubs and hospitals.
Datacard SD360 - plastic card printer - colour - dye sublimation/thermal resin
Printer Type
Plastic card printer - dye sublimation/thermal resin - colour
Desktop
5.4 kg
Max Media Size
CR-80 Card (85.6 x 54 mm)
Print Speed
Up to 200 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm) , Up to 155 cards/hour - colour dual-sided - CR-80 Card (85.6 x 54 mm) , Up to 830 cards/hour - B/W - CR-80 Card (85.6 x 54 mm)
Max Resolution (Colour)
300 dpi
Automatic Duplexing
USB, LAN
RAM Installed (Max)
128 MB
Media Type
Plastic cards
Total Media Capacity
100 cards
Media Handling
100-cards input hopper
Print server - Ethernet, Fast Ethernet
AC 120/230 V
30 months warranty
17.5 cm x 53.9 cm x 22.4 cm
Printer Type
Desktop
Printer
Print Speed
Up to 200 cards/hour - colour single-sided - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 155 cards/hour - colour dual-sided - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 830 cards/hour - B/W - CR-80 Card (85.6 x 54 mm)
Built-in Devices
Status LCD
Wired
USB, LAN
300 dpi
Automatic Duplexing
Media Handling
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Plastic cards
Max Media Size
Card / Label Sizes
Media Thickness Range
0.254 mm - 0.939 mm
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Output Trays Capacity
25 cards
Print server
1 x USB , 1 x LAN - RJ-45
Cleaning pen, cleaning kit
1 x USB cable
VCCI, C-Tick, WHQL, CCC, IC, FCC, RoHS, WEEE, cULus
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Driver
Environmental Standards
ENERGY STAR
Limited warranty - 30 months , Limited warranty - printhead - 30 months
15 °C
35 °C
20 - 80% (non-condensing)
17.5 cm
53.9 cm
22.4 cm
5.4 kg
Scroll to top
