BT.com
Wishlist
D-Link xStack 28-Port L2+ Gigabit PoE Stack Switch
Delivery
Standard 1-3 working days
The xStack DGS-3420 series of next generation Layer 2+ Gigabit switches delivers performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises. With high Gigabit port densities, Gigabit SFP, 10-Gigabit SFP+ support, and advanced software solutions, these switches can act as either departmental access layer devices or aggregation switches to form a multilevel network structured with backbone and centralized high-speed servers.
D-Link xStack DGS-3420-28PC - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE
Performance
Switching capacity: 128 Gbps , Forwarding performance: 95.24 Mpps
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, full duplex capability, power over Ethernet (PoE), BOOTP support, ARP support, VLAN support, IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, sFlow, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Safeguard Engine, bandwidth control, Link Aggregation Control Protocol (LACP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ak, IEEE 802.3at, IEEE 802.1AX
44.1 cm x 38 cm x 4.4 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2)
RAM
256 MB
Flash Memory
128 MB
Status Indicators
Power, RPS (Redundant Power Supply), PoE, link/activity, console
24 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 4 x SFP+ , 4 x SFP (mini-GBIC)
Internal power supply
Redundant Power System (RPS) connector
MTBF
20,619 hours
UL, VCCI, C-Tick, cUL, CB, FCC, RoHS
44.1 cm
38 cm
4.4 cm
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90%
Scroll to top
