BT.com
Wishlist
D-Link xStack 24-port SFP Layer 3 Managed Gigabit Switch
Delivery
Standard Due date unavailable
The DGS-3620 Series xStack L3 Managed Stackable Gigabit Switches deliver great performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises.
D-Link xStack DGS-3620-28SC - switch - 24 ports - Managed
Switch - 24 ports - L3 - Managed - stackable
Enclosure Type
1U
Subtype
Gigabit Ethernet
Ports
20 x SFP + 4 x combo Gigabit GBIC + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 128 Gbps , Forwarding performance: 95.24 Mpps
MAC Address Table Size
32K entries
Jumbo Frame Support
13000 bytes
Routing Protocol
OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, PIM-SSM, policy-based routing (PBR), Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, TFTP, CLI
Flow control, full duplex capability, BOOTP support, trunking, VLAN support, IGMP snooping, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), LLDP support, Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v
44.1 cm x 31 cm x 4.4 cm
4.1 kg
Enclosure Type
Desktop 1U
Subtype
Gigabit Ethernet
Ports
Performance
32K entries
Jumbo Frame Support
13000 bytes
Max Units In A Stack
12
Routing Protocol
Encryption Algorithm
SSL, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
RAM
256 MB
4 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 24 x SFP (mini-GBIC) , 4 x SFP+
Expansion Slots
1 SD Memory Card
Internal power supply
60.2 Watt
Redundant Power System (RPS) connector
FCC Class A certified, UL, VCCI, C-Tick, cUL, RoHS, GOST-R
Software Included
Standard Image (SI) Software
44.1 cm
31 cm
4.4 cm
4.1 kg
Limited warranty - lifetime
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90%
Scroll to top
