BT.com
Wishlist
D-Link Wireless N 150 PCI Adapter
Delivery
Standard Due date unavailable
D-Link's Wireless N 150 PCI Adapter delivers high performance wireless networking to a desktop PC. Based on Wireless N technology with a single antenna, it achieves wireless speeds of up to 150 Mbps and extended coverage with virtually no dead spots. It is compatible with the widespread Wireless G and newer Wireless N technologies and will work with Wi-Fi certified routers or Access Points of any brand.
Securing the wireless network has never been easier, with Wi-Fi Protected Setup (WPS) which works at the click of a button when running the installation wizard.
Installation is a breeze: simply insert the enclosed CD into your computer and follow the installation wizard. A low-profile bracket is supplied for use in slim PCs.
D-Link Wireless N DWA-525 - network adapter
Network adapter
Plug-in card
Interface (Bus) Type
PCI
12 cm x 12.2 cm x 2.2 cm
802.11b, 802.11g, 802.11n
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows Vista / XP / 7
Microsoft Certification
Compatible with Windows 7
D-Link DIR-600, DSL-2680
Network adapter
Plug-in card
PCI
Wireless
Frequency Band
2.4 GHz
Status Indicators
Link activity
Aerial
Antenna
External detachable
Antenna Qty
1
Gain Level
2 dBi
Compatible Slots
1 x PCI
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK
FCC Class B certified, C-Tick, IC
12 cm
12.2 cm
2.2 cm
10 - 90%
Scroll to top
