BT.com
Wishlist
D-Link Wireless-G Cable Router & 4 Port Switch
Delivery
Standard Due date unavailable
The DIR-300 Wireless G Router connects to any modem or ISP box to provide Internet access for computers and other network equipment. Based on 802.11g Wi-Fi technology, it is an entry-level device ideal for a light usage of the network.
Setting the router up is easy even for non-technically minded people, with D-Link Click'n Connect: run directly from the product CD-ROM, this wizard takes you through an interactive step-by-step guide that will get you on-line in a matter of minutes.
A powerful dual firewall (SPI and NAT) prevents Denial of Service (DoS) attacks and attempts to breach your network from the Internet. You can also define a list of allowed sites to restrict web access during certain periods.
With Wi-Fi Protected Setup (WPS), you do not have to memorize complicated passwords and key them in several times. Just press the button on the side of the router, then click from within your adapter's utility software to make the pair automatically generate the necessary wireless network name (SSID) and encryption keys.
D-Link Wireless G Router DIR-300 - wireless router - 802.11b/g - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
Remote Management Protocol
HTTP
Firewall protection, dynamic IP address assignment, DHCP support, NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, URL filtering
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x
14.8 cm x 11.3 cm x 3.2 cm
246 g
Microsoft Certification
Compatible with Windows 7
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
54 Mbps
HTTP
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, FCC
Status Indicators
Port status, power, status
Line Properties
Line Coding Format
CCK, OFDM
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
1
Directivity
Omni-directional
External power adapter
1 x network cable
14.8 cm
11.3 cm
3.2 cm
246 g
55 °C
0 - 95%
Scroll to top
