BT.com
Wishlist
D-Link USB 2.0 4-Port Hub
£20.05
Hurry, only 1 left in stock!
£20.05
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The D-Link® 4-Port USB 2.0 Hub (DUB-H4) provides four additional USB 2.0 ports to your PC or Mac, allowing you to connect USB devices such as digital cameras, external hard drives, flash drives, and printers. Providing data rates of up to 480Mbps*, this 4-port hub is the ideal solution for transferring data between your computer and external USB storage devices.
Simple plug-and-play
Designed to provide quick and easy access, the DUB-H4 is equipped with four type "A" downstream ports for connecting USB peripherals or other USB hubs. The DUB-H4 does not require any software or complicated installation process. It is a Plug-and-Play device that provides seamless connectivity to both PCs and Macs.
You can simply connect the DUB-H4 to your computer and start connecting your USB devices.
Backward compatible with USB 1.1
The DUB-H4 is backward compatible with USB 1.1** devices, ensuring connectivity between your computer and legacy USB devices. Diagnostic LEDs located on the front of the device provide power state and port status.
The D-Link 4-Port USB 2.0 Hub (DUB-H4) is an excellent choice for adding more USB ports to your computer for connecting your existing peripherals as well as adding the latest USB cameras and external storage devices.
For comparison purposes only. Maximum transfer rate based on USB 2.0 specifications. Actual data throughput will vary.
Using a USB 1.1 port will affect device performance.
Header / Manufacturer
D-Link
USB Hub
Networking / Connectivity Technology
Wired
Ports
4
Header / Packaged Quantity
1
Speed
480 Mbps
Hi-Speed USB
Networking / Form Factor (FE)
Desktop
External
Header / Model
H4
Networking / Type
Hub
Header / Compatibility
PC
Networking / Subcategory (FE)
Peripheral sharing and hubs
Networking / Subtype
USB
Miscellaneous / Compliant Standards
VCCI
Dimensions & Weight / Height
29mm
Dimensions & Weight / Width
63mm
Dimensions & Weight / Depth
104mm
Environmental Parameters / Min Operating Temperature
Environmental Parameters / Max Operating Temperature
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* tim - nice not dim
Reviewed by Anonymous on 29/11/2008
My name IS TIM - and I havnt done any decorating. I'm interested that one reviewer has 430V mains power !
seriously though - why does this hub need power - none of the alternative hubs need it? what makes this hub better & justifies 50% extra cash please?
5* USB Power
Reviewed by on 30/11/2008
The hub needs power , as many USB devices draw 5V DC , if you plug four of these into a hub with no power problems occur as the one USB port cant power all four devices,hence the need for a separate power supply,
5* USB hub
Reviewed by andy mac on 23/06/2008
Rob just by the fact that you have a room in your house called the study indicates that probably the archetypal Tim Nice But Dim and are best staying away from electrical items. Obviously you have learnt a lesson, which in life is a good thing, if you plug the wrong psu into something it blows up. Actually you indicate the fact the you are an upper class twit in another way, anyone else would have returned the item feigning innocence to the exact method of the items demise and requesting a new one, instead of posting an item on the retailers webs site admitting the you blew it up. Hey ho. I have the 8 hole version and as Tim, sorry Rob says it comes with a power supply which is nice and as some other inventive soul pointed out it does what it says on the tin, actually I am running a sweep as to how many times that hackneyed saying has been used in the reviews on this web site, I’m saying 1,789,643.
5* D Link USB Hub
Reviewed by Shug on 03/09/2008
Nice little piece of kit - simple to use as XP detects it straight away.
Absolutely no complaints at all about it.
5* Great!!
Reviewed by Patrik on 16/12/2009
Fantastic piece of kit! Have had a problem with power through USB for my Freecom Toughdrive 320Gb, gave D-Link a try and boom. It works!!
Recommend to anyone!
5* Damn it stopped working
Reviewed by on 16/11/2007
after decorating my study I accidentally connected it up to a 430V AC supply and it started smoking. Surely D-link should have anticipated this kind of thing and taken appropriate action. ie not sold it to a dummy
5* D-Link usb hub
Reviewed by Barry on 02/07/2014
I have had trouble powering USB hard drives direct from my computer's USB port.
The D-Link USB powered hub has no such troubles, and powers them up perfectly.
5* No Problemo
Reviewed by Anonymous on 09/02/2008
Took it out of the box and plugged it in - off it went. Doesn't list Vista in the blurb, but works fine.
5* A good buy
Reviewed by Patrick John McNEILL on 16/01/2010
I agree with the recent reviews - this is an excellent product, well worth the money. It works perfectly and is no hassle to set up.
If you need more USB2 sockets, especially if power is needed, then this is the hub for you.
5* unexciting but effective
Reviewed by Anonymous on 08/12/2007
Does what it says on the tin.
Plugged it in and my XP machine detected it straight away.
If I were to be critical, the LEDs are pretty bright and the power one can make the others look like there are items connected on the other ports when there aren't
Scroll to top
