BT.com
Wishlist
D-Link Unified Wireless N PoE Access Point
Delivery
Standard Due date unavailable
The DWL-2600AP unified N single-band PoE access point is a best-in-class indoor access point designed specifically for business-class environments. With high data transmission speeds and access point load balancing, the DWL-2600AP offers high-quality and reliable wireless service. Versatile and powerful, the DWL-2600AP can be flexibly deployed as a standalone wireless access point or as a managed access point controlled by a D-Link unified wireless switch or wireless controller. Businesses can start with standalone mode deployment, and then migrate to a centrally managed system anytime later.
D-Link Wireless N Unified Access Point DWL-2600AP - radio access point
Radio access point
External - indoor
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE
AC 120/230 V
16 cm x 16 cm x 4.5 cm
240 g
Radio access point
Ruggedized Design
Indoor
16 cm
16 cm
4.5 cm
240 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Selectable Channels Qty
13
Load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, 2T2R MIMO technology, rogue access point detection, ceiling mountable, Virtual Access Points (VAP)
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Authentication Method
RADIUS
IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
Internal
1 x 100Base-TX (PoE) - RJ-45 , 1 x console - RJ-45
Mounting brackets
FCC Class B certified, VCCI, C-Tick, cUL, IC, EN 60950-1, EN 60601-1-2, TELEC, LVD, NCC
PoE
External power adapter
AC 120/230 V
10 - 90% (non-condensing)
Accessories
£3.76
£13.50
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£8.31
£52.66
Scroll to top
