BT.com
Wishlist
D-Link Unified Wireless N PoE Access Point
Delivery
Standard Due date unavailable
The DWL-2600AP is an entry level indoor access point designed to enable businesses to deploy low cost managed wireless networks. The DWL-2600AP can work in standalone mode for initial deployment and then complemented by adding a D-Link Unified Wireless Switch or Controller to provide centralized wireless LAN management.
D-Link Wireless N Unified Access Point DWL-2600AP - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
16 cm x 16 cm x 4.5 cm
272 g
Radio access point
Ruggedized Design
Indoor
16 cm
16 cm
4.5 cm
272 g
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Status Indicators
Power, WLAN, LAN
Load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, rogue access point detection, ceiling mountable
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
Internal
1 x 100Base-TX (PoE) - RJ-45 , 1 x management - RJ-45
FCC
PoE
10 - 90% (non-condensing)
Scroll to top
