Click to visit BT.com
BT.com
Wishlist
D-Link Securicam Full HD 2 Megapixel Cube PoE Network Camera
Sale Price - Was £136.98!
Quicklinx: 7XC5WS00
Mfr#: DCS-2210/B
The DCS-2210 is a versatile surveillance solution that is perfect for monitoring low-light environments in your home or small office. It combines a high-resolution 2 Megapixel sensor with a built-in IR LED to help you keep watch over areas in complete darkness. The DCS-2210 also includes a built-in IR cut filter, making it suitable for both day and night applications. Additionally, the DCS-2210 is a complete system with a built-in CPU and web server that transmits high quality video images for security and surveillance. Simple installation and an intuitive web-based interface offer easy integration with your Ethernet network. The DCS-2210 also comes with remote monitoring and motion detection features for a complete and cost-effective home security solution.
The ePTZ feature allows users to select a target region for close-up viewing simply by clicking on the video feed displayed within their browser. ePTZ makes use of the camera's 2 mexapixel resolution to survey a large area effortlessly. Since ePTZ requires no moving parts, there is no need to worry about the camera having mechanical failures.
This network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista/7 to automatically recognize the camera and add it to the network. Sign up with one of the free Dynamic DNS services available on the web to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com), and remotely access the camera without having to remember your IP address. You may also view up to 32 cameras from a central location using the included D-ViewCam software. D-ViewCam has a robust set of features including automated e-mail alerts which can instantly inform administrators of suspicious or unusual activities.
The Open Network Video Interface Forum (ONVIF) is standards relating to open IP video networking. DCS-2210 is ONVIF compliant and therefore interoperable with other manufacturer's products on the same network such as cameras, storage systems, video analytics products and Video Management Systems.
The included D-Link D-ViewCam (DCS-100) is a sophisticated video management software which enables you to manage up to 32 network cameras, set e-mail alert notifications, create recording schedules, and trigger motion detection to record directly to your hard drive or network folder. D-ViewCam also allows you to upload a floor plan of your premises, and create a realistic layout according to the locations of your cameras, further simplifying the management process.
D-Link DCS-2210 Full HD Cube IP Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes : built-in speaker, built-in microphone
12.9 cm x 8.2 cm x 9.7 cm
80 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Optical Sensor Type
CMOS - 1/2.7"
Minimum Illumination
0 lux - IR - F2.0
Lens Iris
F/2.0
Ethernet 10Base-T/100Base-TX
1 - network cable - external
Voltage
DC 5 V / PoE
Motion sensor, date/time stamp, IR filter, sharpness control, saturation control, brightness control, contrast control, ONVIF support, microSD card slot, Privacy Mask Function, text stamp
Environmental Parameters (operating)
0 °C - 40 °C ; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired
12.9 cm
8.2 cm
9.7 cm
80 g
United Kingdom
Camera
Colour - Day&Night - fixed
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1920 x 1080
Digital Zoom
10
0 lux - IR - F2.0
Infrared LEDs
Video Capture
1920 x 1080 @ 15 fps , 1440 x 1080 @ 15 fps , 1280 x 720 @ 30 fps , 800 x 480 @ 30 fps , 640 x 360 @ 30 fps , 320 x 176 @ 30 fps , 176 x 144 @ 30 fps , 1280 x 960 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 320 x 240 @ 30 fps
Image Sensor
CMOS 1/2.7"
Lens Construction
Lens Iris
F/2.0
Horizontal Field of View (degree)
67.4
Vertical Field of View (degree)
40.8
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, RTCP, PPPoE, IGMP, Samba, 3GPP/ISMA
Alarm Inputs Qty
1
Alarm Outputs Qty
1
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
1 x network cable - external
FCC Class B certified, C-Tick
Power Requirements
DC 5 V / PoE
Power adapter - external AC 120/230 V ( 50 - 60 Hz ) 3.5 Watt
Software Included
Drivers & Utilities
Microsoft Windows 2000/XP/Vista/7
Relative Humidity (operating)
