BT.com
Wishlist
D-Link Securicam 18X High Speed Dome Network Camera
Delivery
Standard 1-3 working days
D-Link's DCS-6815 is a high-performance high speed dome Network camera, ideal for business surveillance application. Speed Dome cameras are very popular in CCTV system. DCS-6815 targets professional level market. Use high performance SoC (System-on-Chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-6815 supports dual-codec for live monitoring and recording. With the free-bundled 32 channel recording software, the DCS-6815 is an ideal and professional solution for high quality viewing and reliable recording.
The DCS-6815 is a compact lightweight design high speed dome network camera that includes a weather proof housing which meets IP66 international standard and can withstand the toughest environment. Additional, with built-in heater and fan, the DCS-6815 is capable of operating at temperatures ranging from -45°C to 50°C making it the best choice for extreme weathers.
D-Link DCS-6815 High Speed Dome Network Camera - network surveillance camera
Network surveillance camera - fixed dome - weatherproof
17.2 cm x 17.2 cm x 30.3 cm
6 kg
Wired
Camera
Colour - Day&Night - NTSC, PAL
Optical Zoom
18 x
Optical Sensor Type
EXview HAD CCD - 1/4"
Focal Length
4.1 mm - 73.8 mm
Lens Iris
Auto iris
Panning Range (degree)
360
Tilting Range (degree)
-10 to +90
Ethernet 10Base-T/100Base-TX
Motion sensor, backlight compensation, IR filter, e-mail alerts, image flip, Wide Dynamic Range (WDR), heater, built-in cooling fan, auto gain control, auto white balance
Environmental Parameters (operating)
-40 °C - 50 °C; 20 - 80% relative humidity
Wired
17.2 cm
17.2 cm
30.3 cm
6 kg
Camera
Colour - Day&Night - fixed dome - weatherproof
Video Format
NTSC, PAL
Digital Video Format
MPEG-4, MJPEG
Digital Zoom
12
Exposure Range
1/10000 sec - 1 sec
Video Capture
176 x 120 @ 30 fps , 352 x 240 @ 30 fps , 720 x 480 @ 30 fps , 176 x 144 @ 25 fps , 352 x 288 @ 25 fps , 720 x 576 @ 25 fps
Supported Image Formats
JPEG
Image Sensor
EXview HAD CCD 1/4"
Lens Construction
Optical Zoom
18 x
Focal Length
4.1 mm - 73.8 mm
Lens Iris
Auto iris
Panning
Range (degree)
360
Speed (degree/sec)
Up to 90
Titling
Range (degree)
-10 to +90
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, PPPoE
Alarm Inputs Qty
8
Alarm Outputs Qty
1
1 x network - Ethernet 10Base-T/100Base-TX
IEC 60529 IP66, FCC, RoHS
Software Included
Drivers & Utilities
Microsoft Windows Vista / 2000 / XP
-40 °C
50 °C
Relative Humidity (operating)
20 - 80%
Accessories
£3.70
£12.72
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.83
£49.65
Scroll to top
