BT.com
Wishlist
D-Link Securicam 12x Speed Dome H.264 Network Camera
Delivery
Standard 1-3 working days
D-Link's DCS-6616 12X WDR Day/Night Speed Dome Camera is a PTZ surveillance solution that can cover large areas and low-light environments. Built with a Sony Super HAD-II 1/4" CCD sensor, the DCS-6616 can capture 650 TVL high-resolution video with excellent image quality. A built-in IR-cut removable filter allows the camera to capture video in both bright and dark environments.
D-Link DCS 6616 - network surveillance camera
Network surveillance camera - pan / tilt / zoom
Audio
Yes: two-way audio capability
1.2 kg
Wired
Camera
Optical Zoom
12 x
Max Resolution
720 x 576
Optical Sensor Type
CCD - 1/4"
Minimum Illumination
0.1 lux - colour , 0.01 lux - B&W
Focal Length Control
Motorized zoom
Focal Length
3.8 mm - 45.6 mm
Focus Adjustment
Automatic
Lens Iris
F/1.6-2.7
Ethernet 10Base-T/100Base-TX
Motion sensor, date/time stamp, progressive scanning, SD-card slot, Power over Ethernet, e-mail alerts, image flip, image mirror, Wide Dynamic Range (WDR), heater, built-in cooling fan, light sensor, infrared cut filter
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired
1.2 kg
Camera
Colour - pan / tilt / zoom
Digital Video Format
MPEG-4, MJPEG, 3GPP, H.264
Max Digital Video Resolution
720 x 576
Infrared LEDs
12
Video Capture
720 x 480 @ 30 fps , 352 x 240 @ 30 fps , 176 x 120 @ 30 fps , 720 x 576 @ 25 fps , 352 x 288 @ 25 fps , 176 x 144 @ 25 fps
Supported Image Formats
JPEG
Image Sensor
CCD 1/4"
Lens Construction
Motorized zoom
Optical Zoom
12 x
Focal Length
3.8 mm - 45.6 mm
Lens Iris
F/1.6-2.7
Focus Adjustment
Automatic
Horizontal Field of View (degree)
4.49 - 52.8
Vertical Field of View (degree)
3.4 - 39.7
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, RTCP, PPPoE, Samba, 3GPP/ISMA
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
C-Tick, ICES-003, FCC
Power adapter - external DC 12 V 14 Watt
Microsoft Windows 2000/XP/Vista/7
Relative Humidity (operating)
Accessories
£3.69
£12.63
C2G 2m Cat6a Shielded Patch - Blue
Quicklinx: 8H10 | In Stock
£7.76
£49.24
Scroll to top
