D-Link RangeBooster N USB Adapter
Standard Due date unavailable
Give your desktop or notebook PC the gift of better Wi-Fi connectivity with this RangeBooster N® USB Adapter
Compatible with Windows 7 via simple driver download
The D-Link RangeBooster N® USB Adapter (DWA-140) is a 802.11n compliant wireless client for your desktop or notebook PC. It delivers up to 12x faster speeds* and 4x farther range* than an 802.11g network while staying backward compatible with 802.11g networks. Once connected, you can share a high-speed Internet connection, photos, files, music, printers, and more.
The RangeBooster N USB Adapter is powered by RangeBooster N technology to provide superb wireless performance in the home or office. Connect to a RangeBooster N Router (DIR-625) and experience smooth Internet phone calls (VoIP), responsive network gaming, secure Web surfing, faster file transfers, enhanced audio streaming, and greater wireless coverage in larger homes and offices*. The DWA-140 supports WPA™ and WPA2™ encryption that allow you to connect securely to a wireless network.
D-Link's Quick Adapter Setup Wizard guides you step-by-step through the installation process. Configure this USB adapter without having to call a networking expert to help you. The D-Link Wireless Manager is also included with this product to keep track of your most frequently accessed networks so that you can join them quickly and easily.
With unmatched wireless performance, reception, and security protection, the D-Link RangeBooster N USB Adapter (DWA-140) is a great choice for easily adding or upgrading wireless connectivity to your desktop or notebook PC.
Connect your desktop or notebook computer to a wireless network and access a high-speed Internet connection, transfer files, and stream media from greater distances around your home or office.
*Delivers up to 12x faster speeds and 4x farther range than 802.11g
*Access secure networks using WPA™ or WPA2™ encryption
*Backward compatible with 802.11g networks
*Easy to install and use with the included Quick Adapter Setup Wizard
Maximum wireless signal rate derived from IEEE Standard 802.11g and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-Link RELATIVE performance measurements based on the wireless range and speed rates of a standard Wireless G product from D-Link. Maximum throughput based on D-Link's 802.11n devices.
D-Link RangeBooster N DWA-140 - network adapter
Network adapter
Interface (Bus) Type
USB 2.0
8.7 cm x 2.8 cm x 1.2 cm
802.11b, 802.11g, 802.11n (draft)
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n (draft), USB 2.0
Microsoft Windows 2000 SP4, Microsoft Windows XP SP2
Microsoft Certification
Certified for Windows Vista
Network adapter
USB 2.0
Spread Spectrum Method
Data Transfer Rate
300 Mbps
Line Coding Format
Frequency Band
2.4 GHz
Status Indicators
Ad-Hoc Mode
Antenna Qty
1 x USB 2.0 - 4 pin USB Type A
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
FCC Class B certified, C-Tick, IC
Software Included
Drivers & Utilities
Additional Requirements
System Requirements Details
Windows 2000/XP 300 MHz - RAM 64 MB - HD 20 MB
8.7 cm
2.8 cm
1.2 cm
10 - 90%
The following resources are available for the D-Link RangeBooster N USB Adapter
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Not Good
Reviewed by mr bell on 30/07/2007
Do not waste your money.
This unit caused many problems, unlike my Belkin 54 Mbps unit.
If you like me use a BT Homehub, this only transmits a maximum 54 Mbps WiFi.
So the claimed 300 Mbps is not needed, that’s if it ever works.
Better still use a patch cable from the router to the PC and get a true 100 Mbps.
Or use a Belkin 54/125 Mbps WiFi unit, which works very well.
Have read that the Belkin 300 Mbps unit, is also unstable, unless of course you know better.
Hope this helps,
5* Perhaps not the cheapest but a nippy little thing
Reviewed by Anonymous on 27/01/2010
The problem that Mr Bell is having is nothing to do with the USB adapter. It is either the BT Home Hub (only the 2.0 version supports the 802.11n protocol needed to make full use of the 300Mbps connection) or a device that isn't compliant with the N protocol.
To make full use of the 300Mbps speeds, ensure that all wireless devices connecting are 802.11n compatible (look for Wii, DS as well as PCs) and that your router is both capable of using the 802.11n protocol and is configured to do so.
However, even if your wireless network is not fully 802.11n compliant, it will still work perfectly well at slower speeds. The USB cable can be helpful to get the best signal strength and the install was easy and uncomplicated and took only minutes. The drivers installed from the CD first time, and the rest of the install was as simple as plugging into the USB socket and entering the network info.
Nice USB network dongle for a reasonable price for the latest network speeds.
5* Easy to setup and works fine
Reviewed by Anonymous on 17/11/2007
Very easy to setup and works fine.
I have not had any problems with it whatsoever. Comes with a USB extension cable too, which was a nice surprise.
Installed drivers from CD, plugged into USB, entered wireless network details and it worked! Up and running in just a few minutes. I am using with D-link N Router so this might have helped. Stable signal strength about 60% with no dropouts.
Works fine for me!
5* Does what it says on the tin!
Reviewed by Adrian on 22/05/2013
Very easy to set up and has made a great difference to my connection with Home Hub 3. As my hub is downstairs to facilitate wired connection to my TV set up, I use wireless for everything else.
Well worth the money!
5* GREAT , Get one !
Reviewed by Robert Griffiths on 18/03/2012
Ok Where do i start, don't look anywhere else but this product as 1. it is very stable under 130mps but on the BT hub that mode is B ,G ,N mode and 40MHZ mode is 300mps but the BT infity 3.0 hub is so bad for stable connection at 300mps so i would recommend if you have the bt hub to use the B,G,N mode as this gives the best download speed (4.4 on steam (37MB) as i got the bt infity, ok it does not stay on 130-144mps all the time but when clicking on website pages , downloads , watching HD videos all of these tasks will be working at 100% of the time as this wireless dongle keeps the wireless running very well , so my final summary is if you get this the only problem you might find is download speed depending on what internet you have and just refresh the wireless and this dongle will get back to working at the very best so for 20 pounds or just over you cant go wrong as it has all the latest technology on it and it gives the best wireless output.
5* mariusz
Reviewed by Mariusz Kowalik on 30/06/2011
Reviewed by Anonymous on 08/12/2014
This did not perform as good as my older dongle that was older and cheaper. Item took a week to arrive.
Scroll to top
