BT.com
Wishlist
D-Link Outdoor PoE HD Dome IP Camera with Night Vision
Delivery
Standard 1-3 working days
The D-Link DCS-6315 HD WDR Varifocal Outdoor Fixed Dome Network Camera is a high definition professional video surveillance and security solution suitable for small, medium and large enterprises. The camera uses a high-sensitivity megapixel progressive scan CMOS sensor with onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in video surveillance applications without the need for additional accessories.
D-Link DCS-6315 - network surveillance camera
Network surveillance camera - fixed dome - outdoor - weatherproof
Audio
Yes: two-way audio capability
12.8 cm x 12.8 cm x 11.37 cm
1.112 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
4.3 x
Max Resolution
1280 x 720
Motion Detection
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0 lux - IR - F1.4 , 0.1 lux - colour - F1.4 , 0.02 lux - B&W - F1.4
Focal Length Control
Vari-focal
Focal Length
2.8 mm - 12 mm
Lens Iris
F/1.4
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Manual exposure, date/time stamp, sharpness control, saturation control, 16:9 widescreen mode, brightness control, Power over Ethernet, contrast control, Wide Dynamic Range (WDR), ONVIF support, built-in LED illuminator, Motion Detection Technology, infrared cut filter, Privacy Mask Function, microSD/SDHC/SDXC Memory Card slot
Environmental Parameters (operating)
-30 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired
12.8 cm
12.8 cm
11.37 cm
1.112 kg
Camera
Colour - Day&Night - fixed dome - outdoor - weatherproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Video Capture
1280 x 720 @ 30 fps , 800 x 450 @ 30 fps , 640 x 360 @ 30 fps , 480 x 270 @ 30 fps , 320 x 176 @ 30 fps , 1024 x 768 @ 30 fps , 800 x 600 @ 30 fps , 640 x 480 @ 30 fps , 480 x 360 @ 30 fps , 320 x 240 @ 30 fps
Supported Image Formats
JPEG
Image Sensor
CMOS 1/3"
Lens Construction
Vari-focal
Optical Zoom
4.3 x
Focal Length
2.8 mm - 12 mm
Lens Iris
F/1.4
Horizontal Field of View (degree)
28 - 90
Vertical Field of View (degree)
16 - 58.8
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, SNMP, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, RTCP, PPPoE, Samba, QOS, CoS
Ports
LAN/power - RJ-45 , Audio line in - 3.5 mm jack , Audio line out - 3.5 mm jack
C-Tick, FCC, IK10, IP68
Power Requirements
DC 12 V / PoE
Power adapter - external AC 120/230 V (50/60 Hz) 12.24 Watt
-30 °C
50 °C
Relative Humidity (operating)
Scroll to top
